Hey there!
Can I connect BLI to local music storage (not DLNA server) - either on the device or on NAS on the same local netowkr?
Cheers!
Hey there!
Cheers!
NoHey there!Can I connect BLI to local music storage (not DLNA server) - either on the device or on NAS on the same local netowkr?
Cheers!
Do yourself a favour and add a music-server to your NAS. Then you can use the BLI app for your music collection (searchable)
Note: I stream WAV (up to 192kHz (limitations of my renderers) + DSF files (both in stereo & up to 7.1 multi-channel) using a (dlna) music server.
Would there by any chance be an update that makes the BLGW BeoRemote Halo ready.
Søren
Nope.
Søren
Hi Soren,
As Bw789 said, the answer is no. The BLGW is not in active development anymore and only receives security updates. Sometimes new drivers are made available because the BLI driver is compatible, but this is not the case with the Halo integration.
Søren
Hi Soren,
Would it really be very difficult to add that same Halo support to the BLGW?
Ivan has written earlier:
"Indeed there are some drivers that require new integration methods that aren't available on the BLGW, and are possible with the BLI. These are the systems that you see are not available for the BLGW. But if the 3rd party system doesn't require use of these methods, the driver will also be available for BLGW."
This seems fair enough. The BLGW was introduced in 2014, the BLI around January 2019. The BLI has a newer chipset that can handle more advanced things (such as oauth authentication). Just like your 2014 iPad won't update to iOS 15, there are limits to what you can achieve on outdated hardware platforms.
Still, I think pricing is a factor here. BLGW was about half the price of the MLGW. BLI is still quite expensive. I think B&O could double or triple their sales of the BLI if they cut the price to like 500 Euro in Essential mode.
Søren
Hi Soren,
I personally don't think it's any hard to implement this to the BLGW as I have heard it's almost similar software. Correct me if I'm wrong..
This is just one way to get more sale, And I don't like it
