BeoLiving news & support from Khimo!
Hi Aleksei, glad to see that Carolpa could guide you towards the shortcuts in the start screen! Regarding your first issue
Aleksei wrote:
Proposal: Can it be done that one stays on the Favourites page and able to try other stations until one's happy?
we will take your proposal into account, you have a good point there. For the moment we can advise you that when on a radio source, you can use the next and back arrows to move through your favorite radio stations list.
Miki Sesevic wrote:
Hi!
I have a minor proposal for the Beoliving app.
For all rooms in my home I have created several scenes. Mainly for steering lights, starting products at a certain time etc. Over time the list of scenes grows and I would very much like to be able to rearrange them.
A scene that I create now might be a scene that I would like to have on the top of the list but it will position itself at the bottom since it is the last one created.
In the B&O app, it is very easy to rearrange the list of products simply by dragging the product to the desired position. I wish it would be possible to do in the same way in the Beoliving app.
Could you please take this proposal in consideration for future updates?
Thank you,
Miki
Hi Miki,
It is actually quite possible to do what you wish in the BLI, see the
Thank you for your answer! However, I am using BLI in essential mode and can’t reorder the way you explained unfortunately. My proposal/wish is that it would be possible to reorder the scenes directly in the Beoliving app.
Regards,
Miki
Hello guys @ Khimo
I've just got in my hands a Baoliving Intelligence and I was wondering if a list of supported device exists.
My plan is to move away from HomeKit to land on BLI which I assume integrates better with my B&O sound system.
I have a long list of devices other than HUE lighting system:
Nuki smartlock and Sonoff dimmers, Tado AC and Heating controllers, and perhaps other devices and I'd like to understand what I will have to replace and in favour of what else.
I could consider to switch to PRO mode, if it's required to make it work.
My best,
GLOP
I second the request for Tado firstly as the ability to add a thermostat to the whole house and then the potential to add room stats TRV to each room to call for heat.
Hi!
means Tado is supported in noway?
Is there a way to pass through HomeAssistant or other kind of HUB/Gateway?
GLOP
Hi!
GLOP
GLOP wrote:
Hi!
GLOP
Hello
I dont know about pass through I only know that if you search the forum the topic has come up a few times.
I wonder how much it woudl be for development of the driver as there is a few of us we could group pay for the development to add the driver and get it added.
woudl need to work like Philips hue and you can add resourses to your setup for example I might want to just add the one thermostate to all rooms to control my house as a whole or if you have room stats / TRV perhaps you want that in the room instead.
Woudl be ideal as a driver in Eco mode but more than likely need to be in pro mode
@Khimo Team, How much ££ to develop the TADO driver into the Bli to work as above?
cheers
I send an Email to the Khimo team to find out dev costs to create the TADO driver.
Will be interesting to find out the cost and if anyone would like to jointly pay for it with me to get it built.
I ordered a TADO Wireless Thermostat yesterday and the extension bridge to install this weekend.
cheers
Sean
Please keep me posted. I'd be interested.
GLOP
Count me in for the Nuki smartlocks 😁
