Hi Everyone,
We seem to have accumulated many questions over the last month! I'll do my best to give you some answers :)
benjnz wrote:
In Resources - on Philips Hue for the
sensors and smart buttons there's no obvious listing for them when I
"Load resources form the connected system" I can't notice anything in
the list from the Hue Hub that maybe them, if not would support for
those please go in the wish list?
The Hue API doesn't allow real-time feedback, so capturing the buttons' events would be slow, but we will add it to the Wish List!
Stefan E wrote:
I also stand behind this and this
functionality that exist in the 1st version of BeoLink app, this is the
single reason that keep me use this version instead of Beolink2 and
BeoLiving app.
We could make it so the MasterLink driver saves the last selected source. This would mean that if you change things from the product itself or in any other way without going trough the BLI, the app would still show the source you selected through it, and this might be a bit confusing...
What we propose is that if you think you prefer this solution to the current state of affairs, and if you're willing to test it, you can share your BLI serial number with us at support+mlstate@khimo.com and we will enable a test version for you.
CTR wrote:
Which thermostats can provide temperature input to the BLI app?
Sensibo, free@home, coolmaster and KNX all offer thermostats that can be integrated with the BLI.
benjnz wrote:
I see google have kind of dusted off an API that can work with nest again - link - and that linkis also looking into it, are there any plans for Khimo to do the same?
We are looking into it but cant promise anything yet.
1990 wrote:
I've tried various ways "*/ */SYSTEM/Clock/", "global/global/SYSTEM/Clock/", "/SYSTEM/Clock/". What am I doing wrong?
The correct one is "*/*/SYSTEM/Clock/", the error you are getting is because you have a space before the asterisk!
1990 wrote:
But I cannot figure out how to make a command that enables the
speaker to start at a certain volume. I can only get to this, resulting
in my standard volume of 35 instead of 15. How can I get this to work?
You should first turn the equipment ON by selecting the source, and then set the volume. Something like:
engine.fire("Main/Gym/AV renderer/BeoSound 2/Volume level?Level=15")
engine.fire("Main/Gym/AV renderer/BeoSound 2/Select channel?Channel=1&Connector=&Source Type=TUNEIN")
DocLeisure wrote:
There was just a new firmware released for the BeoRemote Halo - unfortunately without BLI support.
We can still not comment, sorry (:
