BeoLiving news & support from Khimo!
I have the BLGW along with Homeseer for my home automation server and I'd like to be able to trigger BLGW macros from Homeseer. I spotted your comment about sending local HTTP commands to the BLI - can that be done on the BLGW? If so any example URL's would be appreciated!
It is indeed possible to send commands and execute macros through HTTP Posts. As an example, you can see how it is done when wishing to use Siri Shortcuts: linkThese shortcuts can be used on both PRO and Essential BLIs, and can be executed by talking to Siri, or even on the Apple Watch! Which brings me to the last point: We will look into the possibility of some kind of integration with the Apple watch, but we are currently focused on a revamp of the app, it's coming out any day now! Can't wait to hear what you think about it :)
Thanks for the reply and looking forward to the revamped app! Will the http posts described also work to the older beolink gateway (BLGW) that I am running?
Best regards,
Rob.
Yes, works also on BLGW!
Awesome thanks! I'll give it a go later this evening. Rob.
This is fantastic thanks! I've created 2 macros so far on the BLGW, first being "Play Radio 1 on Beoplay M3", and the second "Join Beoplay M3". Tested with Siri shortcuts via voice command on my apple watch and works really well! Very cool. Next up will be shortcuts for my masterlink speakers! Rob.
Hello ebnrob,
did you manage to trigger a BLI macro from your 3rd party home automation system (HomeSeer - right?)? Siri is nice, but I would need the syntax for an HTTP request to trigger a BLI action (e.g. start TV) form my home automation system ("homee" or "Homey"). The HTTP request should also work for other systems...
I am looking forward to any suggestions.
Best regrads
Doc Leisure
Hi Doc,
Not yet, I imagine it'll be fairly straight forward getting homeseer et al to send the same http post requests.
After posting my original question to khimo I worked out that I could trigger macros on the BLGW from homeseer by getting homeseer to fire "LIGHT YELLOW/RED/BLUE/GREEN" IR commands from my logitech harmony hub to my beovision 11 (in the same room). The BV11 then forwards these light commands to the BLGW and the macro is triggered!
Hi Rob,
thanks for your reply. Interesting thoughts - I also own a logitech harmony hub, which is integrated into the "Homey" home automation system. I will give it a try, but it sounds more like a special trick shot than a straight forward HTTP-request ;-)
By the way, for me it is no problem to let the BLI interact with my home automation system. I control my IKEA blinds with the BR1.
BR1 (command) --> BLI --> Custom String --> Web request --> Homey (home automation system) --> IKEA blinds
But I could not figure out, how the home automation system can trigger an BLI action.
Maybe Khimo can shed some light on this ;-)
Looking forward.
Best regards
Doc Leisure
