BeoLiving news & support from Khimo!
It amazes me again, the Khmo Team has done an amazing job integrating all the ML stuff. My BS 9000 works flawless on 7X BS cores through the house. BV 7 works like a charm.
RACHIO solved worked on it with Sebastian and flawless (almost but support was great)
Tested the LG DRIVER on a C8 with BS 4 no need for an ITACH anymore works excellent.
it is just read but you need to take your time. I have being away a long time on the forum as I only got questions no answers that annoyed me. I have made the leap from BLGW to BLI and it has not disappointed me and no one even tested the big update... Connecting the TV is not that difficult
WHY?
double
Hi Ivan
I have a problem with BLGW & Hue
no problem in setting any hue level & color in individual light control
but when I set hue in scene , the color send wrong value, always send xxx.xxx.0
Whatever the color I picked the last value always 0, that cause hue flash then turns off
it looks like a bug in firmware, any upcoming firmware upgrade for BLGW that fix it?
Hi Rick,
We have tried to replicate the error you describe with the last BLGW firmware version and we have not encountered this error. Could you maybe reproduce the error a couple of times and then download a Service Report and send it to us at support@khimo.com so we can have a look?
Hi Khimo team,
I have the BLGW along with Homeseer for my home automation server and I'd like to be able to trigger BLGW macros from Homeseer. I spotted your comment about sending local HTTP commands to the BLI - can that be done on the BLGW? If so any example URL's would be appreciated!
Best regards,
Rob.
Another question from me @Khimo:
Do you plan to update the Fibaro driver to include the thermostats?
That would be great!!!! Including the motion sensors as well would be impeccable!!!!
Hello Khimo team
If / When will the Beoliving app have some apple watch functionality ?
It could begin with the ability to select a zone and turn volume up and down followed by the ability to call a scene and control the lights.
Seanie_230 wrote:
Hello Khimo team
+1 on the apple watch feature request.
I'd also really like to be able to use the volume keys on the side of the iphone while playing music to control the volume on the current zone as well as lock screen controls on the iphone, the same as the b&o app has.
I believe if the beoliving app had the lock screen media controls the apple watch would then show the now playing screen giving us basic control which would be a good start.
Tassos, Your code for the pool lights was helpful and a better streamlined version of something similar I was working on.  Thanks!
Might be a stupid question but what is the Event/trigger for the macro/code?  Time of day? Status update? Is there an "after sunset" time conditional or trigger?
I struggle sometimes with the best methodology to trigger the Lua code to be executed.
I have a soft music playlist play automatically throughout the house at 6:30 every morning.  I put a conditional to keep it from playing on Saturdays so we could sleep in:
function(event, engine)
  if (os.date("%A") ~= "Saturday") then
      engine.fire("Main/global/MACRO/MORNING ALARM/FIRE")
  end
end
