Khimo Support wrote:
Millemissen wrote:
Which means, that - if you are new to the BeoLivingIntelligence-stuff and you still have old ML devices and the NL/ML Converter - you would still have to use/get a MLGW or BLGW in addition to the BLI, right???
That’s a lot of boxes ;-(
Hi MM,
If you have a NL/ML converter then you already have the ML sources shown on the apps as NL ones, so you won't need a MLGW/BLGW.
Best,
the Khimo team
Khimo-
That isn't quite correct. With the NL/ML converter, you see just audio master and video master sources ML products on the NL network. However, this is not integrating link-room ML devices. Previously, you had mentioned to me that using the converter with a BLI would not give full control of ML devices such as we had on the BLGW. Also, those link room devices would not be able to transmit LIGHT/CONTROL commands since they would not be nodes on the BLI. Could you elaborate more on this? I thought that the ML driver integrating an MLGW/BLGW would fill in the gaps of this loss of control. There is much that we really need to understand.
As MM commented, the BLI needs a lot of boxes to integrate ML products. It would have been far more elegant to have just kept an RJ45 ML connection with the BLI!
