BeoLiving news & support from Khimo!
Can you help making one for me, I am not so technical . I'm willing to pay you a fee. I would much appreciate .
Khimo Support wrote:
We are currently in the last phase of development of the new BeoLiving app for Android, the beta version is currently ready for testing and we are looking for users willing to join our beta testers and try out the app on your individual installations!
Is the Android app for BLI only? Or BLGW too?
BLI only
Yes, if we get access to the official protocol we can do it!
Please, email us to support at khimo.com
I finally got my BeoLiving Intelligence!
Unfortunately, it does not work properly. It was easy to install the device on the network, update the firmware, add a BeoPlay v1 TV, several Hue bulbs, but It doesn’t add my newest TV, a BeoVision Horizon. It is rapidly detected in the new devices zone, but when I try assigning the TV to a zone, the circle in the black square turns for several minutes then closes, but the TV remains unassigned. Tried several times, closed and restarted the App, but impossible to assign the BeoVision Horizon to a created zone.
Moreover, after several minutes of normal functioning with the assigned devices, the control of the devices no longer works: the message "waiting for product" appears, then disappears without any possibility to control the device. To solve this problem, I have to reboot BLI each time.
I must say that I’m a bit disappointed as I thought that there wouldn’t be any problem with the newer B&O TVs and the installation. Think will send back BLI and keep my MLGW!
Can you verify if your BeoLiving Intelligence is running the latest firmware (v2.0.1.377)? You can check it directly from the BeoLiving App  [Settings] -> Device -> Check for updates.
Once in version v2.0.1.377, please, try again.
Thanks, the Khimo team.-
Updated BLI to v2.0.1.377 after both BeoVision Horizon TVs and the remotes updated to the latest firmware as well: now everything works fine.
Thanks for the prompt response.
Hi Khimo team,
I have a BLGW and have tried to connect my Dahua IP camera's to the BLGW without any success at all. Note the Dahua Ip camareas are connect though an Dahua NVR box.
1. Does the BLI Support the Dahua IP camera's ?
2. And would there be a difference to the BLGW in terms of Dahua IP camera's support?
3. Does it make a difference if the Dahua Ip camere's are connect though a Dahua NVR box?
4. Aslo, can you integrate the a Dahua doorbell (dahua vto2000a) with BLI?
FYI . Im anyhow planning to upgrade to BLI but I haev some basic thing i need to has to work first.
/Jens
Until recently, it had been possible to use the Ikea Tradfri light system by pairing the lights with Philips Hue and using the Philips Hue driver. However, it seems that a recent firmware update of the Philips Hue bridge no longer allows pairing the Tradfri lights with Hue. Could you add a driver for us to integral the Ikea Tradfri lights directly with the BLGW?
2 Essences, a BS35, BS Shape, 3 BLC all have their own Line in.
Not that I use them all, but I would appreciate a feature to rename these sources in the BLGW or Beoliving software.
