BeoLiving news & support from Khimo!
Thank you very much for your response . Which camera do you recommend that it works well with BLI ?
I prefer battery power camera to be free for cables
I don't know any battery powered camera that works with the BLI, sorry 🙁.
Any camera that supports  MJPEG (HTTP) should work, we also support MP4 (RTSP) cameras. To watch the video stream in the TV MJPEG is mandatory.
Thank you very much for your response . We want to instal a radiator thermostat from tado ,will this work with BLI ?
Currently, we do not have support for tado, if they have an API we can make the driver by request. We can also add it to the driver wishlist and if we got enough requests we will make the driver.
You can find all the currently supported devices at the following URL:
https://khimo.github.io/help_drivers
Soon we will add drivers for VENSTAR T4800  and some Honeywell thermostats.
Best.-
Will this help ?
http://blog.scphillips.com/posts/2017/01/the-tado-api-v2/
Hello, the beoliving app when run on an ipad (on ladscape) it shows a security tab. What exactly is this and which security systems are supported?
thank you
claudiu wrote:
It seems they have the API! To make an official driver we will need tado to assign us a ClientID and a secret. But, any of you can code your own driver simply by following that API.
thank you
From there you can control and monitor your alarm system, currently you can integrate:
I would not advise linking the security system to any home automation except for triggering via the alarm such as lightning.
Never an input such as unset etc.
