BeoLiving news & support from Khimo!
Tassos wrote:
Hello again,
I am experimenting with the lua code you sent me for the nightmode: home / nightmode: away. I am trying to create a macro to automate my pool lights.
Pool lights are connected to mains via a tplink smart plug. Music is procured by an NL/ML Converter. What I am trying to achieve is that 30 minutes after sunset the pool lights turn on only if the NL/ML Converter is playing. I haven't succeeded yet and I need a bit of help since my lua knowledge is very limited. The lua code I am using is the following:
Hello Tassos,
Good work! You almost got it!
The name of the state variable is "state", so the conditional that  check the status should be:
if nl_ml_converter.get("state") == "Play" then
Also, since you have the pool_lights_address defined, it would be better if you the command using the variable:
engine.fire(pool_lights_address .. "/SET?VALUE=false")
In this way, if you update the variable definition in the future all the commands will be updated.
Please, let us know if you have any further question!
Best,
the Khimo team.-
Thanks a lot guys! For all the help and the quick responses!!! By the way, any news on the Somfy driver?
Khimo Support wrote:
We are glad to announce that you can now directly integrate Google Assistant with the BeoLiving Intelligence. You will find it listed inside Google Assistant, Home control settings.
Will this also work with the BLGW?
It may work, but there is no official support for the BLGW.
Do I need a account at Khimo for remote access and the possibility to connect to Google assistant on the BLGW?
Isn't there going to be any support anymore on the BLGW, only on the BLI?
Google assistant works using Khimo remote access service.
The BLGW is in maintenance mode, no new features will be added but the software will be fixed if necessary.
Tassos wrote:
Hello again,
Hello Tassos,
Best,
the Khimo team.-
Hello again, lua coding seems very easy and actually a lot of fun. I have a small issue though. I have "automated" my virtual led buttons to change state according to the state of the lights they turn on/off. The system monitors the lights (hue) every minute and if they have a value other than 0 then the led of the button turns on. If the value is 0 then the led of the button turns off. It works like a charm but when I use a variable after the fire command nothing happens.
this is the code:
function(event, engine)
  -- Define the resource address in your project:
  local dimmer_level_address = "Main/$zone/DIMMER/*"
  local dimmer_button_address = "Main/$zone/BUTTON/Lights"
   -- Get dimmer state
   local dimmer_level = engine.query(dimmer_level_address)[1]
   if dimmer_level.get("LEVEL") == "0" then
       -- the button led should turn off
       engine.fire("Main/$zone/BUTTON/Lights/_SET STATE?STATE=0")
   else
       -- the button led should be on
       engine.fire("Main/$zone/BUTTON/Lights/_SET STATE?STATE=1")
   end
end
At this version the fire command doesn't use the variable but I want to use the variable as you suggested.
Furthermore can you give me an example of an "if" "and" and an "if" "or" condition? For example:
"if" the pool lights are on "or" the converter is playing then.....
"if" the pool lights are on "and" the converter is playing then....
Thanks a lot!!!
   end
end
Thanks a lot!!!
It's good to see you're enjoying LUA macros and generic programming too!
Regarding firing using a variable, you should use this:
       engine.fire(dimmer_button_address  .. "/_SET STATE?STATE=1")
In link you can find more info about the logical operators in LUA, some examples applied to your use cases:
  •  "if" the pool lights are on "or" the converter is playing then.....
  if  dimmer_level.get("LEVEL") ~= "0"  or nl_ml_converter.get("state") == "Play" then ...
  •  "if" the pool lights are on "and" the converter is playing then.....
  if  dimmer_level.get("LEVEL") ~= "0"  and nl_ml_converter.get("state") == "Play" then ...
Enjoy it!
   end
end
Thanks a lot!!!
In this URL you can find more info about the logical operators in LUA, some examples applied to your use cases:
Enjoy it!
thanks a lot!!!! I am already experimenting with the logical operators and I have to admit that it opened a whole new world for me. I am also checking the url you sent me and it is super useful. I couldn't be more happy!
Thanks again!
How can I connect arlo pro 4 hd-camera to BLI ?
As far as we know, Arlo cameras are quite closed and do not allow local integration. Please read the following responses at their forum:
  • RTSP support: link
  • Still image support:
