Beolit 600 Radio - How much?
I am thinking about buying a Beolit 600 Radio in good condition. How much should I be wanting to pay?
Thanks.
Which model Beolit 600?
link - probably between £50 £ £100
- probably between £75 & £125
I'm using eBay as a guide here & prices depend on several factors - condition, willingness of the seller to post & quality of the listing.
Like all ebay sales though, there are bargains to be had if you search hard enough.
Chris.
Hi Chris.
If u want a radio as good as new, u migth consider this dealer in Denmrk:
Well, I bought one from eBay and it arrived damaged. Does anyone know of something that stocks parts for these items? I think its a 1965 version.
Hi Chris.
What is damaged? Some pictures would be nice.
Peter, DK
I just won a curry Beolit 600 for 42 euro. It has a boken antenna but looks in good condition otherwise. I bought it for the curry panels and for spares because my black Beolit 600 has a slightly damaged bottom plate (broken plastic foot). Maybe I will try to restore both units if I can find a spare antenna. Are these available?
Hi Agent.
I gues u are talking about an 1970 beolit..  Silver frame?
I migth be able to help u out whit an atenna and perhaps some "Footwork"
Best regards
Peter, DK.
Yes, it's the 1970's model. It seems the frame is actually curry-coloured. I'll give a report when I have received it from the seller and have assessed the exact condition. Thanks in advance for your offer.
/Jörgen
Now I have received the curry radio and done some cleaning. The only really broken parts are the antenna and one of the supports for the ferrite bar. The bottom plate is OK but the retaining pegs for it are missing.
On my black radio the plastic foot in one end is damaged. This is riveted to the bottom plate so maybe the entire bottom plate needs replacing. One of the pegs for the bottom plate is missing too.
My original idea was to make one perfect radio out of the two but if the broken and missing parts can be replaced, both radios could be restored. Here are some pictures of the pair (the curry radio partly disassembled):
