My BeoLit 12 has suddenly and inexplicably gone dead. It is nearly always plugged in, and the battery light was green the day before the following occurred. The device was plugged into an electrical outlet and I was listening to music on it from my iPad, connected via USB.
I unplugged the iPad, and then turned the BeoLit 12 off. The next day, it was dead. It will not turn on. I attempted to reset it, both a soft reset (using the power button) and a factory reset, but it seems to be dead.
I don't know what is wrong or how to fix it. This one was a replacement after issues with my original one.
I received a reply from Customer Service that the battery must be dead and if it's in warranty, blah blah. Or get a new battery. My local B&O has closed. I am assuming it is no longer in warranty, so...
Does anyone know where I can get a new battery, can I replace it myself, and an idea of cost?
I am disappointed in what is turning out to be an expensive paperweight. Items of this quality and price shouldn't die after a year or two.
Thank you for any advice!
-Casey
