I received a package with some components from Conrad. Login to view image
My Beolink 7000 with very weak back-light. Login to view image
Assistant Login to view image
1. Remove the two screws Login to view image
2. Remove the cap. Login to view image
3. Remove the last two screws. Login to view image
4. Remove glass panel, don´t touch the inside. Be aware that the small four corner nuts don´t fall out. Login to view image
5. Test the voltage. Should be around 130V Login to view image
6. Disconnect display pcb from the other units. Be gentle with the ribbon cables. Login to view image
New electrolumiscent film. Login to view image
Testing
Login to view image Login to view image
7. Slide fixing rails to the left and remove them to release the LCD front frame. Login to view image
8. Remove front frame Login to view image
9. Unsolder old film. Login to view image
10. Unfold LCD display. Try not to touch the surfaces, especially the inside. Be very careful with the "rubber" profiles still on the glass. Those are the actual leads from the PCB to the LCD, if the will be miss positioned or contaminated with dirt dust or grease you will get an improper or faulty readout from the display. Login to view image
11. Remove the luminescent foil. It's attache with two stripes of double sided tape on the backside.
Login to view image
Old and new. Login to view image
12. Mark the size. Assure that you get the lead in the same position. Login to view image
13. Cut it to correct size.
Login to view image
Ready for assembling.
Login to view image
14. Mount the new foil in position with two stripes of double sided tape on the back side. put the leads through the holes in the PBB. Login to view image
15. Solder and reassemble in opposite order as the disassembling. Login to view image
16. Testing....I do believe it's working...good...
Login to view image
17. Adjust the LCD contrast.
Login to view image
Potentiometer for contrast adjustment of the LCD.
Login to view image
18. And now the recapping, unsolder and remove tin housing. The five now visible capacitors should be replaces. The two violet ones to the left, the two smd´s in the middle and the green one to the right. This has been described in other threads so I won't go deep into it.
Login to view image
19 Prepare the new components. Login to view image
20. Soldered in place.
Login to view image
21. All components changed. Be careful with the small smd´s, the can be tricky to solder due to its small size. I also changed all other electrolytic capacitors. Not necessary now but just precaution.
Login to view image
22. Reassembled and working perfect again.🙂
Login to view image
