Ok, I've now installed the kit in one of my for-parts remotes. And it looks great! 🤒
The installation instructions (linked above) were good. The kit relies on a new PCB being soldered on top of the old one and I had issues with one or two contacts not making it all the way. With the help of the creator I was able to find the issue and fix it (I ended up using one extra jumper wire as I couldn't get the RST line making good contact).
My remote needed some work as the battery holder (a flimsy design to start with) was slightly damaged as was the mount post associated with it.
The remote I worked on had it's LCD flat-flex already ripped off so it was beyond repair, and a perfect candidate for installing the kit. I have one more physically much nicer BL5000, which has most of it's original display still working (link, although it did lost some lines some time after the repair). That one I would not tear apart, but with any other BL5000 with already messed up LCD (cable) I wouldn't hesitate to consider this kit!
I must admit the BL5000 is not one of my favourite remotes, but I hope enough people with skill and gear can get these kits from pilatomic and get at least some of those dying BL5000s back to life!
Most of the process is already shown here in this thread, but here are couple of shots:
The old LCD cable (left), the LCD controller IC and some other parts are removed from the Beolink's PCB using a hot air station:
Login to view image
Then the e-Ink board is soldered on top of the board:
Login to view image
The solder points on the e-Ink board make contact with the pads on the old PCB, and only the VBAT jumper wire (top) is needed. I had issues with one the contacts not getting thrue, so I added an extra jumper wire (bottom wire) as I didn't want to remove the whole thing and risk breaking off pads:
Login to view image
With heat-gun the original top-glass panel can be separated from the old LCD panel and re-used with the new e-ink display. The result looks very nice! It's see-thrue as original, but I do consider this a worthy replacement!
Login to view image
