CLOCK: sw 2.0
CONTROL: sw 1.3
Many thanks. My other CONTROL one is at SW 1.3 but it's in a box somewhere and I can't dig it out..
I was wondering if my SW2.2 CONTROL one may actually be a CLOCK version with replacement lower buttons because I cannot get CONTROL to work with either my BC9500 or BC2300 - but perhaps these Beocenters are not CONTROL compatible. Anyone know?
If it shows the time on the back of the display when you press CONTROL, you have a CLOCK version with different buttons. There is no negotiation whether it should use CONTROL or CLOCK. Only BS6500/7000 supports CONTROL to my knowledge.
/Weebyx
