Hi
At the moment I can't afford to buy a new Beovision but I still have my lovely Beolab 9 and Beolab 8000. I would like to connect it to a non B&O TV with a Onkyo TX-NR1008 receiver. I tried several settings and now it is working. Unfortunately, the sound is not very good. (I know I should use a BeoSystem)
Does anyone know which setting is recommended. I don't know how much ohm and Hz I can choose for my Beolabs. I am afraid I will destroy the speaker by using the wrong configuration.
If someone is using also an Onkyo receiver: which setting do you recommend for the sound? DTS, THX, all channel, etc.?
Thank you very much in advance
