Beolab penta mk3 vs beocenter 9500
Got two beolab penta mk3 hooked up with my beocenter 9500.
Got no reading on the speaker display, got the switch on the bottom of the speakers switched to audio.
Anyone any ideas wether this is correct/wrong , any sugestions how to make em work?
greetings from the netherlands.
Fully wired powerlink cables are used?!?
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Stevie - you're specifically going to need to connect the speakers with MK2 Powerlink cables for the displays to work.
Hopefully that's all it is.
Good luck!
Greg
They are used now and it is working now! Thank you!
Did that and the displays are working 😊👍🏻
