I don't recall praising the use of film capacitors in crossovers in particular.
At first I thought it was a great idea to replace electrolytic capacitors with film capacitors. Mainly because they (at least in theory) should last forever.
I even made capacitor kits containing film capacitors for several of the larger B&O speaker models.
But many buyers reported back, that they didn't like the sound of the speakers after the rebuild to film, and a few
even asked me to revert their speakers back to electrolytics.
I wondered about that, but also had to admit never listening seriously and for longer periods of time to speakers rebuilt
with film capacitors, so I sat down and did exactly that. My conclusion was, that they were right, - the sound was wearing on the ears.
Where I could listen to "original" speakers for hours without experiencing any fatigue, I grew tired of listening to
the ones rebuilt with film capacitors fairly fast. In the best of cases I honestly couldn't tell any difference from electrolytics, but in the worst of
cases I felt a relief when switching off.
I also came to the conclusion that the speakers, filters and everything was designed for using electrolytics, and
if any other type of capacitor would've made them better speakers, B&O would've used that.
I no longer provide film capacitor kits.
Feedback from buyers made me aware, and I feel that the, at times very steep, prices of the film capacitors can't be justified.
As mentioned earlier, some owners may actually like the sound of the film capacitors, - a sound that I like to refer to as "modern",
because it seems that's where many speaker producers are heading, but it's not the typical and well-known "B&O-sound", - it's not
what B&O intended and it's not the original and warm sound, I prefer myself.
Another thing is, that the film capacitors are often quite bulky in size and rarely fit particularly well in the filter boards.
This alone can be a challenge to some DIY'ers.
Some film capacitor types are so big they need to be placed elsewhere inside the speaker cabinet, which again requires extended lead lengths = not good for cap specs.
What I recall praising was Die_Bogeners modifications to the amplifier section of Beolab Penta.
A few coupling capacitors and some OpAmps are replaced for newer types.
This is not done to improve the sound reproduction as such, - actually the sound isn't colored notably, but it dramatically
improves the signal/noise ratio, an area where the active Pentas with their "volume control" constantly at max can use all attention obtainable, and
it also takes care of certain older OpAmp types that are notorious for injecting their own noise into the signal, so is absolutely worth doing.
These modifications also got included (with Die_Bogeners accept) in the amplifier rebuild kits I make.
But it's all a matter of taste.
If you like the "modern" sound then by all means go ahead and fit film caps (keep leads short and fasten everything so nothing rattles or breaks their solder joints), but if you want the original sound I recommend staying with electrolytics.
