Hi all,
First time poster here at Beoworld!
I came into possession of a pair of Penta MK1's (Australian version, 6605?) around 6 months ago and had them refoamed, but have only recently got stuck into their failing amps. I only tried them briefly to check their state, but intended to use Martin's recap kit before I started proper diagnosis (might as well give them a fighting chance, right?). During that initial test, one flicked from red to component protection mode (yellow) when a signal was applied, and the other exhibited a crackling sound with what sounded a very muffled version of the track playing at a low volume.
In the last couple of weeks I refreshed both units using Martin's fantastic kit (caps, IC2, pots), and the same issues persisted. After giving the crackling one a good going over (I'll have a look at the other one this weekend as I anticipate it may be a little easier to diagnose), here's where I'm at right now:
- The speakers work great sans amps, and I have double checked that the crossovers are in good condition until I can recap these later. We can rule them out as a point of failure.
- The large transistors around the outside test fine, I have re soldered them to ensure that there is no cracked joints. They have a good and fresh thermal paste application and have never been run not attached to the heatsink.
- I've resoldered the pins for the front panel based on the recommendations of some threads
- I've also tried swapping the front panels of amps to rule them out as an issue
- There is no visual indication of damage to any component on the board
Are there any other common failure points that could be causing this crackling audio? At the moment I'm just going through and testing every component on the board so any advice would be greatly appreciated!!
And yes, I'm probably a little nuts not to just ditch these amps but I am a purist and won't let them die! 😎
Cheers, Matt
