i'm restoring a pair of beolab penta mk1's i bought and have come across a problem with them that i could use some help with.
when i turn on the speakers i can hear a static sort of noise from all of the drivers on one of the towers but only from the tweeter on the 2nd tower, they both play music fine but with the static noise still slightly audible in the background. i have stripped both speakers down and cleaned them and performed a visual check on the pcb's and components for the usual damage ie heat,cracks,bulging and it all looks to be in perfect condition.
i should say that they are connected to the beomaster 5000 through the speakerlink conections on both ends with 2 pin din plugs.
now onto the beomaster problem
the system comprises of a beomaster 5000, beocord 5000, beogram cd50, beogram 5500 & mcp5000,terminal 5000.
the main problem i have is with the mcp's 2 way coms not always working it seems to be tempremental.
any help/advice would be greatly appreciated.
james.
