It's always a good handrule to start with trimmers in center position.
The circuit will have been designed for a point not far from that.
DON'T use the markings on the board for capacitor polarity reference. They are not always correct! Actually, there
are quite a few typos and misprints in the silk-screen.
I normally advice to replace one component at a time, using the old component for polarity reference.
You probably have a good photo, that you can use for reference, that'll be fine too.
Anyway, I think, I would have diagnosed and repaired the bad amplifier module before upgrading and
replacing a lot of components.
If the new components doesn't cure the original fault, and you've inadvertently introduced a
new fault somewhere, it could end up a very difficult situation.
And in case the amplifier module turns out to be a complete write-off, you've lost money and time too.
