Just started an overhaul of my 30 yr old Pentas and have been trawling through old forums but not found a definitive answer to the above question. Given that the drivers are the same in both version 1 and 2, as are the quoted crossover points, I have to assume that the changes were made for technical reasons or sonic improvements. Anyone know if either or both apply?
I have already replaced the mid-range foams with Audio Friends' units - excellent fit, highly recommended, and have the cap and upgrade kit from Martin for the amps. I have just pulled the crossover boards (well, 3 of them so far as the fourth seems to be nailed in..) and all seem good with no burnt bits. Only noticeable item is a dented cap - bad form B and O... Surprisingly all of the mid-range drivers' foams were intact, although very tired looking.
I'd appreciate knowledgeable comments before I order new bits but I don't intend to fit super duper foot thick caps, or replace speaker leads with hawsers to improve sound ; )
One thing I did notice - they seemed a damn sight heavier than I remember them being. Must be getting old.
