Martin,
You're right - it is some statement, and I'll stand by it.
My workshop organization, cleanliness, environment, workmanship, ability and attention to detail is far above any norm, and the results show.
It would also exceed any critical industrial standards, even though I have no need or intention of applying for certification.
After working in the Israeli electronic industry, arguably among the most advanced in the world (based on the equipment we are proud to produce and export world-wide), I learnt what a proper electronics workshop should be, and I duplicated it in my own workshop.
Based on what I've seen on YouTube technician videos, I also realize that not many technicians have the privilege of creating an ideal workshop like mine.
It may be difficult for you to accept, but I really don't need anyone's approval, other than that of my customers worldwide.
I'll address your related concerns further down
It's common knowledge that B&O had quality issues in the past, and they've done a great job at attempting to solve them, evidenced at least by the good quality of some of the components in these PCB's.
However, every one of the SMD caps on the Black ICEPower PCB was far off-spec, measuring the ESR and capacitance out-of-circuit after removal.
I expected that, and the replacement of those caps, solved the Orange light overheating problem.
So, at least on this machine, that is evidence of failure-prone SMD caps.
It's a well known problem that during the SMD PCB manufacturing cycles of Preheat and Flow, the Electrolytic caps take a beating at those temperatures.
SMD caps are subjected to destructive heat cycles which Leaded caps were never subjected to.
And current Electrolytic chemical technology does not yet have a solution for that.
So, it stands to reason that any SMD cap, no matter the make, starts off its life partially crippled.
For at least 40 years, my solder of choice is Kester 245. I have 2 versions - one 63/37 and 62/36/2.
They meet all the requirements for my varied applications.
If we're talking about vibrations, my goodness, then what is Unleaded solder doing on these PCB's?
Unleaded solder barely manages to keep from cracking under even the best conditions.
If vibration is a valid argument, then that should be a good enough reason to forbid the use of Unleaded solder on these PCB's.
Since you ask about problems with SMD capacitors, let me throw a four-letter word in here. B-se.
I have repaired literally HUNDREDS of B-se Wave PCB's, ALL with failed SMD capacitors.
It is an absolute reliability disaster, and an insult to the customers for the prices they ask.
There are probably other manufacturers just as bad, but I can speak only from my personal experience.
The BL9's were opened on our spare table - plastic, simply to spread out the parts, which were then taken into my workshop, as required.
At that stage, I was certainly not concerned about ESD.
That photo is NOT in my workshop.
We do NOT own any carpets - not sure where you got that from. Carpets are not common in Israeli homes.
I don't see any need to post any photos of my workshop, apart from that on my
