Beolab 8000's as PC speakers
I am looking for the best way to integrate a pair of Beolab 8000's as my PC speakers.  I am smart enough to know ask ppl like you for advice.  Should I get a DAC and preamp?  I really appreciate any advice to keep it clean and masterful at low volume levels.
Welcome to Beoworld! :)
If you have a "noisy" soundcard in your PC or if it makes plopping sound when switching on/off you shoud use some kind of DAC / preamp / USB-Audiointerface. They give you more comfort regarding volume control, too.
If you have analog outputs on your PC you could get an old tc electronic Desktop Konnekt 6. They are extremely cheap nowadays, provide very good quality and control. If you have a firewire connector on your computer you can use it as an audio interface, too:
http://www.tcelectronic.com/desktop-konnekt-6/
A similiar but pure digital solution exists from tc electronic and is called BMC-2. It's a DAC/preamp/Monitorcontroller and accepts various digital input formats:
http://www.tcelectronic.com/bmc-2/
Otherwise you can use every USB-Audiointerface that fits your needs:
https://www.thomann.de/gb/usb_audio_interfaces.html?viewMode=block
You just should have a look if it has a knob for output volume control. Than you don't have to use software to adjust the volume of your speakers. A simple and powerful interface is e.g. Novation audio hub.
or just use monitor controllers between your computer and Beolabs:
https://www.thomann.de/gb/search_dir.html?sw=monitor+controller&viewMode=block
Steve from soundsheavenly can sell you every cable you need.
I would get a Beomaster 6500/7000 plus remote and a 3,5 to Aux cable....
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I used beolab 18er speakers.  As there is no volume control in the speakers, it is worth investing in a USB dac with volume control. I used a IFI IDSD Nano and was happy with the sound. Going straight from PC/Mac to speakers means relying on software volume control and can cause moments where the speakers see full volume which is not good for relationship with neighbors nor speaker units
