Good tip from Marc, had the same problem; orange light for a while, so cleaned out the foam. Light went back to red, but no sound, so checked the relay and one track was looking ropey - quick check with a meter confirmed that the track running around the edge of the board was corroded as I was getting no connection between the relay and the connector.
Quick solder of a wire and job done!
