Beolab 8000 Amp Modul removal & repair [Solved]
it looks like the original replacement kit for one speaker.
awesome, I was not really sure about it because the foam in mine looks black and less dense.
Any advise about where to buy spare parts (like the internal power section plastic support)?
Thanks for your kind support, gentlemen!
[View:https://archivedforum2.beoworld.org/members/tedg332/default.aspx:800:0]
Hello,  I fixed my speaker but can't figure out how to insert pictures.  If you go to the media section on the site, I put them there.  My fixing advice:
The foam is a gooey mess, don't get it on your clothes.
The amplifier section lifts out- it is the whole black aluminum piece- the wasn't sure from the pictures.  I used a heat gun on low- and held it a foot and a half away so as not to fry the unit.
The fix was easy once I was able to get the grill off and the amp out.
Good luck!
When using the iPhone app you can easily use the kamera button to insert pictures from your phone.
Hi to all forum members,
after years of absence I ran into the same problem: Left speaker failing and showing orange light instead of green when turning on the system. I can fully second tedg332's hints about the "gooey mess". And due to this forum repair was easy and straight forward!
Speaker playing fine again. Only questioning if I should open the right speaker too 😂
I tried to dismantle amp but apparently my version is 6801 and it has different design where the amp is one piece to the end and holding the LED as shown in picture. Anyone knows how to take this out?
https://imgur.com/a/fBRqOX6
