Thank you very much Mika.
Your tips were great! The Modul was not glued but only stuck on the old gasket.
1. I took off the gasket on the right lower corner near the modul
2. While heating with a hairdryer (not heatgun) I took away 1mm of the gasket between the modul and the tube using a sharp knife
3. Now I could get a 3.0 mm flat screwdriver into the little space I opened with the knife.
4. Still heating I pushed the screwdriver under the module half a mm after half mm.
5. I used a electro work screwdriver as the plastic isolation does less harm the aluminium when bending the screwdriver to lift the modul
6. Once it came off I saw the messy foam you talked about, there was only a little of it on the PCB ass you can see in the picture above. It was on the outer trace to the relay. I realy thought trace could not be harmed.
7. Testing the trace with the Ohm-meter , there was no contact between the starting points of the trace.
8. Cleaning it all up with some alcohol I got this view of the trace:
Login to view image9. I soldered a new "trace" for each of the contacts of the relay:
Login to view image10. put all together again and the speaker now works fine !!! 🤩 🤩 🤩
THANK'S THANK'S THANK'S
gerard
