I just used the tranparent craft stuff which usually has a red backing.
Yes excellent solution for the beolab8000 if you have a tight budget😁
Absolutely brilliant! Top workmanship and a great idea. I never actually thought of putting a pair of ladies tights on some 8000's, so kudos for thinking of such a low-cost solution.
I'm not sure what the next step is for your 8000's after this. What about replacing the iron bases with these? LOL !!
😮 - Are they yours???😮😮
Hi
great idea and result
well done
can you please confirm the size of pantyhose you chose?
thanks a lot
Hi
well done
thanks a lot
I just opted for the biggest size available. Too much fabric is better than not enough ;)
😂😉 make sense
thanks a lot 👍
