5500 Beocenter line out , two Beolab 6000 as loudspeakers. one side is switching on from red dot to green dot and playes music. the other side remains calm and red dot! Turning the the bottom up of the malfunctioned Beolab 6000 and unplug / plug the audio signal this loudspeaker starts working also!
does somebody knows where I have to start searching for the fault? It seams , that the start peak of the audio signal is to weak to switch the amplifier on.
thanks for your inputs
regards Ueli
