Beolab 5000 (60:th), 2N3055 in the power supply breaks when speaker is connected
I am repairing a Belab 5000. All capacitors have been changed. The Power supply is repaired with new transistors, new 18V zenner and show correct values (60V, over the 33V Zenner diode about 34V).
The problem is when I connect a load, a pair of speakers (RL150 or others) then at power on it's a "pop" sound in the speakers and the two 2N3055 transistors in the power supply breaks emediatly. The voltage then raise to about 76V (short circuit in the 2N3055). The fault occure indipendent of volume.
The amplifier works, I have checked it whith tone generator and osciliscope. It also works when the power supply gives 76V with the speakers. I checked the 2N3055 in the amplifier with a Huntron Tracker (desoldered).
Some earlier repair has been done on this unit, one of the 38647 in the amplifier has been replaced with another transistor type.
Any good ideas on where to start?
My thoughts are:
1) Problem with the batch of 2N3055? I have checked the 0.22ohm in serie with the transistors.
2) Problem with the current reduction through the 0.22ohm in the power supply, maybe change the resistor to a higher value?
3) Problem with the 3000uF caps to the speakers? They have been changed by someone earlier to correct value but much smaller type. (They measure ok).
1. Most likely
2. The emitter resistors are not for current reduction.
3. Not likely if they measure fine.
Where did you buy the 2N3055?
And can we see how they look?
Thank you Martin for a fast reply.
1) The 2N3055 come from a workshop that I bought so its not possible to trace the actual source. What do you recommend for make of them to be sure its original? Here is a picture of them:
2) No it's not the emitter resistors, there is one more in the power supply with the same value as the emitter resistors. According to the service manual it should reduce the current at 7A. My idea was to change it temporary for fault finding. But first option is to check the 2N3055 and maybe order new ones.
Gunnar
Gunnar
That transistor is a counterfeit/fake.
See this:
ok, I will order new transistors.
Thank you
Gunnar
Perhaps it would be a good idea to show them to us before ordering.
Or find NOS or even good used ones.
I hadn’t seen this thread.
Yes, as Martin says, definitely counterfeit or fake 3055’s. You would be surprised if you opened one 😎
Even real noughties ones tend to pose problems on devices that used the original RCA ones.
The best bet is to buy untouched old 60’s and 70’s amps that used RCA or Motorola ones. They are aplenty and usually very, very cheap.
Ok, I will see what I can find.
Gunnar
I just wanted to add that not all of  ST's 2N3055's are counterfeits.
I did order a bunch of them from a distributor back in 2013 when I heard about ST givin' up the production.
After reading here I tried to rub-off the printing with alcohol; it faded somewhat but was not erasable. See lthe left front transistor
And I notice a bit more "digital" print font on the transistor compared to the other picture in this thread.
Does anyone have a description of the printing on it? I searched the net and my datasheet collection but couldn'd find a valid one for the 3055 (Martin?). I think these are 2013 Week 24 and from Malaysia.
Haven't used one of them yet but this one being in a lot of electronics from times gone (power supplies, amplifiers...) I decided to get enough for the rest of my electronic life :-)
I'm hoping that they weren't counterfeits already in 2013 ;-)
  hx
