I am repairing a Belab 5000. All capacitors have been changed. The Power supply is repaired with new transistors, new 18V zenner and show correct values (60V, over the 33V Zenner diode about 34V).
The problem is when I connect a load, a pair of speakers (RL150 or others) then at power on it's a "pop" sound in the speakers and the two 2N3055 transistors in the power supply breaks emediatly. The voltage then raise to about 76V (short circuit in the 2N3055). The fault occure indipendent of volume.
The amplifier works, I have checked it whith tone generator and osciliscope. It also works when the power supply gives 76V with the speakers. I checked the 2N3055 in the amplifier with a Huntron Tracker (desoldered).
Some earlier repair has been done on this unit, one of the 38647 in the amplifier has been replaced with another transistor type.
Any good ideas on where to start?
My thoughts are:
1) Problem with the batch of 2N3055? I have checked the 0.22ohm in serie with the transistors.
2) Problem with the current reduction through the 0.22ohm in the power supply, maybe change the resistor to a higher value?
3) Problem with the 3000uF caps to the speakers? They have been changed by someone earlier to correct value but much smaller type. (They measure ok).
