I have had a Beolab 5000 for some months now, but haven't had time to test and restore it properly until now. Too much studying 😎 also I have been working on recapping a couple of beovox 2400 speakers. Anyways, I just tested the beolab 5000 a couple of days ago, and to my dismay I noticed that the right channel had a much lower output then the left one 🙁
Other things I noticed:
- There is a crackling sound on the right channel when I turn it on and off
- If i turn the volume up and down alot it will suddenly work, eg the right channel will be on the same level as the left
- I have swapped the speakers around and tried different input types, and the problem is always on the right channel
Do any of you know what can cause this? I am guessing I got a faulty capacitor somewhere... Is this something I can locate and fix myself?
I hope someone can help me solve this.
