Recently both of my BL5 have been fitted with a new chassis.
after this one of the 2 speakers played about 6db less loud than the other. Thinking this was a chassis issue they installed another new chassis in the more silent speaker, same problem. So we thought that the speaker which played louder was the problem and we installed the chassis we just pulled out of the other speaker and moved it to louder speaker. But still the difference stayed the same.
after that we swapped the chassis again between the 2 speakers and after that it appeared that both speakers played at the same volume. However in the speaker that used to be more silent one of the wires of the microphone n was loose and it was not possible to calibrate the speaker.
so the wire got repaired and we calibrated the speaker, immediately after that the volume difference was back, the same speaker played 6 about 6 db less loud than the other.
so my conclusion is: the volume difference is not caused by the chassis but by something that happens during calibration. But the wuestion is what can cause this? I always assumed that the calibration would only affect bass but to my ears the entire spectrum is affected.
is it for instance possible that something is wrong with the microfone, for instance a constant hum which affect the measurement and causes the dsp to play everyting at a lower volume?
or maybe the bass speaker has a fault which is not detected by the protection circuit which causes this?
when the calibration runs one speaker also seems to be making different tones than the other.
thanks,
Eric
