Hi There
I have a pair of Beolab 4000 mk1, one of which works fine and the other powers up but no sound. I have removed the gunky foam, and the main (large) board has just one corroded spot on it. A tiny SMD 100 ohm resistor appears to have bitten the dust. Ot perhaps eaten the acid would be more correct. Would that give the symptom I describe possibly?
Two fuses were covered in a white dust, but test good.
Also what else should I change while I am there?
Thank you in advance!
Berni
