You are reading the resistor rings in the wrong direction 😕
It's really a 10 Ohm resistor (brown, black, black, gold). I think you already got the answer in your french post (my french is only very minor...)
The yellow might be a hint because this is a safety - non-flammable resistor that opens if overloaded.. I think they are called NFR (non-flammable resistor)
So you should't use an "ordinary" 10 Ohm.
But - I was opening one of my BL2500 just to find them - replaced by a piece of wire 😉
This was new to me; they look original, correctly bent and inserted. It was serial no 11149xxx.
An older one (08826xxx) had the resistors looking like the one in your picture.
Did they change that in series later on, eventually because of the number of "burnt" safety resistors? Maybe Martin as an expert will chime in ...
hx
