beolab 2500 no led light
1. Are these resistors really only 10 Ohm ?
2. If one blows, does it necessarily follow that the other will ?
Me again !
Just a thought, - Before I replace these resistors (they've both definitely blown), does anyone know whether I should be looking for why they've blown or is it simply that it's probably through age etc. ?
Age? Why? A resistor will still work in 1000 years...
A capacitor will not.
Replace at least C16 220uf...
Thanks for that Die_Bogener,
C16 checked out ok. - Any other components I should check ?
Also anyone any answers to my 2 queries from 02-19-2015 above ?
Just to let everyone know that I replaced R19 and R20 and all seems OK !
Only hope I've addressed cause not symptom !
I have also had to replace these resistors on 3 pairs of 2500s, in all cases in both speakers, very strange
Stuart
hi was it only 10hm  (x1 on multimeter) thanks
I have the same symptom on one of my two BeoLab 2500. it does not and I do not have red LED. By cons I have the R19 and R20 that are defective. So a big thank you Beobuddy My question is about the scheme is noted 10! is this 10 ohm resistor? Because my resistances have bars: yellow, gray, black, black, brown logically have to put 480 ohm 10 ohm or 480 ohm (well 470 because 480 found in stores)? thank you very much
Hi everyone and sorry for the text i m french and it's traduction google🙂
my resistor (photo)
for me is not a 10 ohm
Can you confirm please if i buy a 10 ohm or 480 ohm
thanks
