Beolab 1700 a new lease of life
 I purchased a beolab 1700 amp back in 1974 I still have the amp and I now intend to bring it back to life it hasn't been used for 35 years I have made a visual inspection of the electronics  and have removed the 3 large filter caps 1 looked as  if it was ready to pop like a balloon  I thoroughly expect to have to replace all the caps, I have some experience in hobby electronics so the physical part soldering ect is no problem but I do need advice on what caps will give me the best sound, and are there any modifications worth considering on the amp I am hoping there will be others on this forum who have already carried out this update/revamp
And can point me in the right
direction
Thanks Dave..
Dave... T
Contact Martin (Dilan) he will have a kit to restore it back to glory. I still have mine that I bought new in the 70s and it still sounds great.
Plus upgrade to silver or gold and then you have access to the manuals.
Keith
K. Parker
Thanks Keith that's just the advice I was hoping  for. Can't wait to have it all up and running, a empty house (very rare) and dark side of the moon.
Dave..
I also have the Beomaster 1700 tuner, plus my original Beogram 1202 ( refurbished motor bearings) and my original Beovox 1702, not the best but not bad, all I could afford at the time, never had a tape deck but I use a Beogram CDX with it now.
Good choice of record, I also like Wish You Were Here
K. Parker
I also have the  1700 tuner and the 1202 turn table both purchased recently,  I intend to  fully overhaul these items as well but I am just taking it one at a time,  I originally used the amp with a goldring lenco gl75 and celestion County speakers it sounded superb, the turntable and speakers bit the dust years ago .
Dave
