Hi Steve,
I just received the splitter, thanks for the quick delivery.
Unfortunately, it does not work as expected. This is what I experienced:
- Only Beogram connected to splitter --> OK for sound and control of turntable
- Only Technisat DAB+ receiver connected to splitter --> OK for sound
- Both devices connected, but Technisat switched off --> very muted and heavily disturbed sound from Beogram. Control of turntable works
- Both devices connected, but Technisat switched on --> only sound from Technisat to be heard.Control of turntable works.
Do you have any Idea on how to solve the issue? Here some details of the setup for your information:
Beogram 4500 with original 7 pin connection. Technisat Digitradio
110 IR, connected via audio out (3.5 mm jack plug and cable into a 3.5
mm jack to 5 pole DIN plug adapter; the Technisat has no line out, the
only other option is an optical out). The adapter does not cause the problem. If only the adapter with the 3.5 mm plug and cable attached is connected to the splitter while the Beogram is playing, everything is fine. Only when the second 3.5 mm plug is then connected to the Technisat, the problem starts.
Best regards
Francis
