Beogram CDX Only right sound at start and left start after 10-15min
i have a Beogram CDX, i love this player but mine have a little default.
when i play a cd only right sound channel works and after about 10/15 min the left channel  start and after i can listen many cds witthout problem. But wheni din't use it after a fews hours. The same problem reappear.
I start by check visually all composant, i didn't see anything and i try to restore the vias  like i see in this blog :
Common problems:
- The signal cable breaks internally about 5cm from the plugs,
- The muting relay(s), which are of the reed type.
- The capacitors in the analogue circuits, actually on the entire decoder board , have started to give up. I would replace the lot.
Thanks,
i check the cable and no problem.
relays was good.
i change capacitors on the decoder board and restore all the vias and now it seem to be good.
Thanks a lot :)
