Was wondering if anyone knew the value you of value c4 on Beogram 8002 Mine is blown apart and tho I believe it is a.47uf@ 100v replacement just wanted to check before putting it in. Thanks
Beogram 8002
yes that is right cap. stuck it in and ifs up and running.
another question about the beogram 8002 I have a problem with the circuit board the houses the din plug for the output of the table a number of wires were broken off the board looked at the schematic and not very good at solving this issue. I have it wired from left to right first solder tab Blue,Brown White, White, ground, ground,grey , Violet, Black. If this is not correct does someone have the correct wiring diagram or can they look at their board and let me know the order....Thanks so much I have searched the formuns and have found nothing
Here is the output board on one of my Beogram 8002 turntables.
Here is an old picture I found of another BG8002 project. It shows the output board in question and the source of the wires connected to it.
Not all output boards are the same.
Different types of relays were used through production and the boards differ accordingly.
Thank you so much for your help and kindness!
Hi.
I have a similar problem and I was hoping someone would be kind enough to complete the following diagram by writing in the appropriate numbers.
This avoids the confusion about different coloured wires being used.
I do believe the 3 wires shown on the right, that do not connect between the 2 boards, are however the colours shown on the right.
Thanks for your time.
Stuart.
