Hi guys,
After getting my Beomaster 8000 running again with your help, I thought it would be nice to get the Beogram working as well.
The problem I'm having is this:
As soon as I plug it in, the TT starts to rotate, displays 33.33. It responds to the speed controls (+,-,45,33), but it does not respond to any of the other buttons. Every time I plug it in, the tone arm moves to the right a little until it reaches the micro switch. When it arrives in this position it won't start playing when plugged in, but remains in standby like it should. When I hit play the tone arm moves to the left about a centimetre and stops there. From here on out it is non-responsive to anything other than the speed controls.
I have just finished replacing the caps but unfortunately, it didn't improve the situation. Quite strange because I did find a cap that was completely blown in the microprocessor housing. I am testing in the service position, but I assume this should not be the cause of the problems.
Any ideas on what to check?
