But really is goes all over the place depending how fast or slow i rotate...
🙂 Yes, that's normal. When you spin the rotor manually, the motor turns into a generator and the generated voltage will throw off the multimeter. You're not supposed to spin the rotor but "reposition" it, ie turn it slowly and gradually in steps of 45 degrees or so.
Anyway, that's just an info for the future. Apparently your motor is fine since an external power supply can drive the whole mechanism without problem.
60 ohms seem still high to me, but maybe this motor is designed as low current, low torque model.
upon pressing " < " : P1-2 = 2.8V, P1-1 = 0.48V
upon pressing " > " : P1-2 = 0.48V, P1-1 = 7.7V
[...] Now the strange thing is that now i measure 3.34V from pin 22 of IC1 to GND and 5.16 from 21 to GND. 😂
The components that have been replaced since the first time are the Zener, the OpAmp, and caps C28 and C2
Thanks! That clears things up. The 3V from the CPU is the problem. The opamp works as a differential amplifier and the level of the input signals determines the output.
With your unit unplugged, measure resistance from pin 21 and 22 to GND. If pin 22 somehow finds a low-ohm path to GND, it would explain the reduced voltage. Normally you should read a high resistance value on your meter.
You should also check for cold solder joints, damaged PCB tracks and anything odd/suspicious in that circuitry around IC2 and the path from pin 22, IC1.
Afterthought: When you measure 3.3V on pin 22, is the supply voltage on IC1, pin 9 still at a solid 5 volts or is it being pulled down??.
