manfy wrote:
I'm not quite sure how to interpret your voltage measurement...is that across the motor terminals?
Yes it was across the terminals by operating the < and > buttons.
I did the above mentioned test again more carefully and i have the following readings.
upon pressing " < " : P1-2 = 2.8V, P1-1 = 0.48V
upon pressing " > " : P1-2 = 0.48V, P1-1 = 7.7V
As for the motor i stand corrected. I measure 10.4mA when i supply 6.42V with no load on.
Resistance is 59.5 ohms across the terminals and by turning it slowly it gets to 70 (or 45 depending on the direction of the rotation) and then settles again to 59.5. But really is goes all over the place depending how fast or slow i rotate...
Now the strange thing is that now i measure 3.34V from pin 22 of IC1 to GND and 5.16 from 21 to GND. 😂
The components that have been replaced since the first time are the Zener, the OpAmp, and caps C28 and C2
By the way with the motor disconnected from the board when i connect it to an external supply providing 6.5V it spins perfectly and traverses the sliding chassis with no hesitation at all. So i eliminate any mechanical problems there. After all i have cleaned and re-lubed the relevant gears.
