Hi all,
I have an issue with my beogram 4500. The servo motor does not work. When i operate the arrows, the deck responds and does what it should (starts spinning, raising tonearm turning the light on) but will not move the sliding chassis. Also the sliding chassis will not advance as the record progresses. The string is OK, and so is the servo motor, it seems ike no commands reach the motor. Any suggestions from where i should start?
Thanks.
