There was indeed a problem with these motors back in the 'seventies when the product was still current,and the bearings were unlikely to have dried out in only a year or so?
One of the "urban legends" was that the motors were designed for 220v use,and so were slightly over run with the Uk power supply at 240v,making the coils overheat and eventually become "tired"This also seemed to happen with some Thorens decks that used similar induction motors.That argument doesn't hold of course for USA models running at 110v,where the motor coils are switched into parallel rather than into series,as with European spec?
We used to measure the cold resistance of the motor coils before proceeding with a repair,just in case this had happened,so as to save wasted time stripping down the motor,and getting a"bouncing" repair later,with attendant stroppy customer!
The motor's were made by Bogen for B&O,and they were/are jolly good when working properly too.
If a re-lubricated motor performs correctly at the right speed,but then gradually reverts to type(slow),then it suggests that the re-lubricating need's extra attention as Martin and other's have suggested.
If it's consistently slow though,it seems as though you have a "bad 'un",and will need to investigate the coils.A member here did have some success rewinding the coils,so it might be worth searching in the archive.
Do you have another Beogram of a similar type,that you could compare motor winding' s with?
I may have a note somewhere of coil readings,I'll have a search,but I may be a "while".
Regards,
Nick
