I recently acquired a Beogram 3000 (type 5228, built in 1974) with a motor that barely turned. Using instructions from this forum, I disassembled, cleaned, reoiled and the motor turned normal speed. In fact, it seemed to work perfectly for a few weeks, and now it is having speed problems again. I've read just about everything posted on the subject online, on this forum and others. Has anybody solved the motor problems that plagued these turntables?
I ordered a rebuilt SP12 (not cheap) and now I don't even know if the turntable will be usable. I certainly can't enjoy listening to it with the speed jumping around.
Before anybody asks, the belt is new, the idler rubber soft, all parts have been cleaned and reoiled/greased, switches cleaned with 1000 grit sandpaper.
Thanks in advance,
Sean
