Hi all,
I hope it's ok with the moderators to start a new thread on a problem that I've previously posted? The last thread seems to have run dry so I figured starting up a new one might help? Please bare with me because I am not a technician of any kind, just someone trying to get his old turntable up and running again.
I have owned this Beogram 2000 Type 5240 since new. It has been in storage for 30+ years. I have taken the motor apart and lubricated the bearings by vacuum. I needed Martin's (Dillen) help to do this. I have also replaced the LIFT button holder as mine had broken, again with Martin's help. But nothing else within the turntable has been dismantled other than a new belt and cleaning and applying lubrication. Admittedly I had to disconnect the wiring running from the motor and relay to remove the motor, which caused a few issues when re-assembling, but I believe this now to be sorted.
My current problem is that for some reason the motor doesn't stop when I press the LIFT button, the platter keeps spinning. The pickup arm raises from the record (sometimes) but that's it. To stop I have to unplug from the mains.
I have checked the micro switch below the LIFT button and found no problem. I have also manually re-aligned the cam mechanism by turning the platter by hand to 'end of record' but this didn't sort the problem. I have visually checked everywhere I can see but nothing shouts as being broken or loose.
My attention is now on the relay, not least because this is the first component that receives electrical instructions from the LIFT button. I wondered if the relay could be dirty and needed a thorough clean, or more likely perhaps, a component inside the relay is faulty? I'm not sure how one would test for relay component faults?
I've already cleaned the contacts accessible through the relay opening with IPA but this hasn't improved anything. ADMISSION - I have sprayed contact cleaner into the relay but only a little. I did this some days ago and before I read a thread from Martin saying NEVER spray contact cleaner into the Relay - because it contains particulates that can ultimately cause overheating and fire (sorry Martin). The cleaner I used was Kontact 60.
I wish I could undo using contact cleaner but unfortunately I'm stuck with my mistake (the specialist I spoke to from where I bought the cleaner said it should be ok but I doubt we were talking about the same thing.
So... it is possible I have damaged the relay by using contact cleaner. But first, does my problem sound like a relay issue? Are there other areas to check?
If not, then Is there a way to test the relay, can I replace any faulty components found, or worse case swap the relay out for a working unit?
Is there a technician local enough to help identify if the relay is faulty? I'm in Southampton, Hampshire.
Thank you, Carl
