I always liked the look of the classic Beogram 1200s so when I found one on an auction site I bid for it and won. It was listed as a project piece as the seller had tried to replace the belt a failed. Supposedly there is a bent copper bracket somwhere which I haven't seen yet. Some parts came in a plastic bag so I hope everything is there. Unfortunantely the platter was loose and not secured during shipping so it has damaged some of the loose parts. The drive wheel is not looking well at all. It is badly warped and slightly loose from the axis. I don't think it is salvageable. Do any of you guys have a spare one that you could part with?
Regards,
Mikael
