Today I replaced the belt on my Beogram 1000, so therefore I had to remove the plate and all that. It works flawless now, though I'm having a bit of a problem getting the spindle adapter back in place (which also holds the little plastic plate in place as well). The problem is that I can't seem to get the two disks (shown in pic) back into place, which holds the spindle adapter and plastic plate in place. The holes are much smaller than the pin they're mounted to, and how am I to get the weird disk (marked one on my pic) back in place since it isn't rounded. I know that these to disks were there from the beginning, it was hell getting them off. So what should I do, anyone have a clue?
