Thanks for that info.
I did a partial tear-down.
I'm used to complicated transports (Nakamichi Dragon, ect)
However, I count "4" idler type wheels. All in a very small space. - yikes
I discovered a small "L" shaped arm, with a small idler on the back of the transport, it was very stiff on it's pivot, it would not return freely enough. I cleaned that up, and it moves well now, however I've done something wrong, as the take up reel is now stuck.
Supply reel moves fine, and the idler arm I cleaned is coming into play as the take-up reel will try to move this time, however it is jamming up, and of course I no longer have any transport function.
I've looked, and it seems okay, however not knowing what a good transport is "supposed" to look like, I'm a bit lost.
I've worked on other transports before, but I'm in the dark on this, I thought I put everything back properly.
Question:
Can I access everything from the back? I don't want to disturb the head assembly if I can help it.
Is there a clear diagram or photo of the relationship between the idlers and reel tables?
Mike
