Hello All! I have been a lurker for a while, Love this site, and I recently scored a Beocord 8004. I picked it up for a song at a local garage sale as the owner said it didn't work. Got it home, plugged it in, lights! I pressed play and (forgive ALL my terminology) the lower deck that makes contact with the tape rose and dropped, and made normal tape deck engaging sounds.
As per your awesome posts and photos, I opened it up and saw the belts were completely disintegrated and the motor fuse was blown. I ordered a few fuses (to have a few extra in case they immediately blew again) and a belt kit off ebay. The old belts has disintegrated into a black tar goop that stained everything it touched. What a foul substance. I cleaned it up pretty nice, and waited for parts.
Fuses arrived as did the belt kit. I also acquired some sewing machine oil and some silicone grease for my Beogram 4002 (separate acquisition). I replaced the fuse first and looked at the motor. It spins! I then replaced the belts and put the unit back together. Put a tape in and pressed play.....
The tape started for a split second and theeeeennnn sloooowwwwwwwed stop! I pressed play again and engage, disengage. I tried rewinding and it started slowly then went! then slowed and stopped.
I took the tape out and spun the two ...tape nubs... the guys that actually turn the tape (where you stick a pencil to rewind a tape).. and they feel gummed up. I turn them and they totally turn but not easily. like they're clogged up if they could be. My Beogram 4002 would not drop its tone arm because it was so gummed up I had to scrub the old stuff off a rotation point, and re-lube it. I'm assuming something like that needs to be done here.
So! Does anyone have a lubrication guide or a path for me to follow on how to un-gum the two tape post nubs? I feel I'm close to a working unit. I'm curious why the belts died in the manor they did and why the fuse blew. Probably tried to play over and over and over on the gummed up unit and blew the fuse for the motor, and then it sat and the belts melted.
Thoughts?! I'd love to hear your input. Thank you for reading!
